TF 2.5 or RE 2.0??
Old Dec 29, 2009 | 01:19 PM
AZ Outlaws's Avatar
Default TF 2.5 or RE 2.0 Coil Spacer Lift??
Opinions please...
My '08 JK 2 dr X is riding on 285/75-16 BFG MT KM2's. My rear fender flares rub a little when out on the trail, more if loaded with extra fuel and camping gear. I don't want to trim the fender flares, nor do I want larger tires than what I have now.
I've read over what I can find on the subject and am still scratching my head... so I'm asking for opinions on which lift to get. I use my JK as a DD and go off road on easy to medium rated trails 1~2 times a month.
Cost not being a factor, which would you guys go with:
- Teraflex 2.5" BB coil spacer w/shock extenders??
- Rubicon Express 2" BB coil spacer w/longer Monotube shocks??
I'm leaning towards the 2" RE lift... your opinions please, and why??
Thanks
Old Dec 29, 2009 | 04:23 PM
AZ Outlaws's Avatar
Anybody???
Old Dec 29, 2009 | 05:11 PM
Surf38's Avatar
Thumbs up
I have the RE 2in BB and love it. I run 33in Coopers and have plenty of room. The tires stuff up nicely and I have no rubbing at full flex. If spacers is the way you want to go then you wont be disappointed with the RE. The shocks ride much better than stock X shocks.
Old Dec 29, 2009 | 05:49 PM
ajchiz's Avatar
Default How much did this cost you?
If you don't mind me asking...kindly advise how much total did this lift cost you including installations?
Thank you,
Al
Old Dec 29, 2009 | 06:00 PM
AZ Outlaws's Avatar
Originally Posted by e-jeep
Well AZ ...worst case scenario ...I'll let you know how the 2" REs work out in a couple weeks.
I did some more research... I'm going with the RE 2.0" kit because of the longer shocks. Somehow the TF 2.5" kit with the shock extenders sounds a tad ghetto to me.
I'm getting them the first thing tomorrow morning at a local 4wd shop. I'll give you a first impression sometime later tomorrow. I'm also going with JKS Quicker Disconnects. Don't have the $$$ for better gears. In reality, the 3:21 gears aren't that much worse with the larger tires I'm running over the stock Rubi tires that were on it.
Thanks for your reply!!
Old Dec 29, 2009 | 06:39 PM
Loadbreak's Avatar
I have the TF 2.5" BB lift w/ shocks and that seems to work great for me. You really can't go wrong w/ TF stuff. It seems like a very complete kit especially if you get the one w/ the shocks, as they are for 0-3" lift. So if you upgrade the lift to a 2.5" coil or 3" coil you can use your same shocks. I have nothing against the RE lift at this point though. My vote is for TF. Just MHO.
Old Dec 29, 2009 | 07:00 PM
NorthRiver's Avatar
What about a body lift? You can get a 1 1/4" body lift for about $100 bucks.
Should solve the slight rub if thats all you're trying to accomplish.
Old Dec 29, 2009 | 07:17 PM
greenryde's Avatar
I have the teraflex bb on my daily driver with 33 inch cooper stt tires. I also do some mild wheeling a couple times a mounth. I have had no issues with the lift what so ever. The ride was a little stiffer at first, but you get used to it, the flex is amazing from stock to this set up. I also have the tf quick disco's, very easy and fast to use. My vote is for terflex
Old Dec 29, 2009 | 07:48 PM
Sethmark's Avatar
I'm a LONG time Rubicon Express fan. I bought my first lift from them in 1998.
But the TF 2.5" BB kit with shocks is a better kit for performance. Longer rear sway links, drop bracket for the brake lines, and the rear track bar bracket all add up to better performance in a budget boost.
The RE kit is inferior. And it pains me to no end to say that.
Old Dec 29, 2009 | 10:10 PM
Surf38's Avatar
Thank you,
Al
I paid $350 for the kit. Did the install myself in my garage. Very simple install took about 2 hrs all you need is basic tools and some tall jack stands. Before I did it myself I was quoted 200 for the install from my local shop.
