TF 2.5 spring with or without spacer in front?
i got my TF 2.5" spring lift today getting ready to install on my 4 dr. rubi. i haven't decided on tires yet 33 vs 35. i'm going to start with shock extenders & try that & probably add longer shocks later. i want at least a level stance or slightly up in front. this is primarily a DD. do i need a spacer in front to eliminate rake?
Thanks
Thanks
My understanding (since mine is in the box sitting next to the jeep in the garage) is that the front will give you 1/2-1" more lift than the rear to level the jeep out. If you've got a really heavy bumper and winch then think about the spacer, but honestly you should be good without it.
When I did the Teraflex 2.5" coil lift with shock extensions my front end ended up a little in the air as you want. I did not add any spacers but my JK is a 2 door. One I put a front bumper and winch on, it leveled out nicely in my opinion. Here is a picture after the lift was installed.
Attachment 36903
Attachment 36903
I installed the TF 2.5" BB (new shocks and spacers all around). Then I installed the TF coils up front and mine(07 unlt rubi) sits a little nose high with a warn 9.5ti and the XHD stubby bumper. I'll be upgrading to 35" tires this spring so it should fill out nicely.
The 2.5" TF coils alone will give you a good level stance (3" lift up front, 2" lift rear). When you get a bumper/winch combo you can add a 3/4" spacer up front to get your stance back since you'll lose about 1/2"-3/4" with a full width bumper and winch. That's where I'm at and love it ...
I'll probably go 35s. It really depends on how much I drag my guts at EJS.
