TIRES ARE COMING! Things to prep? Help plz
All right so I just spent more money than I am willing to realize at the moment on my new set of wheels
Rim
KMC XD Addict 798's in 18x9 (5x5) 4.5" backspacing
Tire
Toyo M/T 38x13.5R18's -True inflated tire diameter from manufac. spec. 37.7"-
I have a full set of spidertrax 1.5" spacers but I DO NOT really want to run them, the heaviest tire/wheel set possible is going to be putting enough strain on my 44's as it is.
This being said, what preparations do I need to make for these tires to fit. I have 4" Tuff Country lift no body spacers, pucks, etc.
I know I have to trim the stock rubi rails and the pinch seams, what else?
Suggested axle upgrades? gussets, sleeves? what will/won't help axle strength due only to tire size/weight.
Thanks
Rim
Tire
Thanks
I've got the Big SLR ready to go w/ plenty of space
The more I think about this the more I feel I should be putting an order in to M.O.R.E. for the body lift ASAP.
Also trying to install the BL with 38's is going to be a task...I don't have mountains of 2x4's lying around to reach the gap from jack to frame
I'm pretty much counting on the rub w/inner fender plastic
The sway bar links will need to stay connected until I can find a nice spot to get a full flex test run in. I'm more worried about the LCA's in the front getting knicked on full turn in/out.
I'm probably going to hang on to the spacers even if I don't use them as a DD, I like them on the trails
