TF FlexArms lenght, need help
Old Mar 21, 2010 | 12:47 PM
MD5's Avatar
MD5
Default TF FlexArms lenght, need help
After long waiting next week I will install the following:
- TF 2.5" Lift Kit w/shocks
- TF FlexArms (front lower)
- JKS Front & Rear Adj. Trackbar + Rear TB Brace
Today I took a look at the Control Arm, very massive!
I then set the length as stated in the supplied instruction. For a 3" lift, to reach 4.5° Castor, the following value are suggested:
Driver side: 23"-1/8
Passenger side: 23"-1/4
The difference is basically a full turn of the joint.
The instruction say that the length difference is needed to "eliminate the tendency of the JK's to pull to the right".
I would like to know the reason of this tendency and if you agree/suggest to use control arms of different length.
Thanking in advance for any advice.
Old Mar 21, 2010 | 12:54 PM
mkjeep's Avatar
Mine had no pull to the right with 35's, it got a pull with the 37's prolly cause they were abit wider. Got one arm a tad longer, it helps but it's still there a little. Originally set them equal. Drive it and see what you think, adjust from there.
Old Mar 21, 2010 | 12:56 PM
Marshall's Avatar
I have the exact same setup! I set mine as they suggested, and my vehicle drives perfect. If your unsure, start at 23" and see how it drives...Good luck!
Old Mar 21, 2010 | 01:04 PM
bOLsAK=3's Avatar
I have mine equal lengths at 23 1/8 and no pull with 35" mt's.
Old Mar 22, 2010 | 11:53 AM
MD5's Avatar
MD5
Thanks all for the information, I will start at 23" both and later fine tune the lenght.
Old Mar 22, 2010 | 12:00 PM
NorthRiver's Avatar
I installed the same TF lift yesterday. I went with 23" on both control arms and my Jeep drives great. It drives straight and true with no pulling either direction.
