TF Performance vs Budget Leveling Kit
Hi All, I want to put a leveling kit on my jeep. What is the difference between the performance leveling kit (coils) and the budget leveling kit (spacers)? They are both listed as 1.5", so I'm assuming that they both are going to put 2" in the front and 1" in the rear. Can anyone with experience attest to the ride difference? or possible stance difference????
I had the pucks on my old 08. Pucks will sink after a while thus lift hight shrinks.
If it was me and I wasn't going no taller than a 33 tire. I'd just do the puck lift. I had no problems with it after I installed a steering stabilizer. Cause if the pucks do break down, they are an easy fix, cheap too. Now if your wanting to go higher I'd go ahead and get a quality lift an do it right the first time.
The BB may still leave a slight rake and if you run heavy bumpers you may lose some height due to the weight. The LK which uses coils will eliminate the rake and the coils were designed to handle the weight of aftermarket bumpers should you choose to install one later on.
