TF rear Axle bracket
two questions...
i have a jks adjustable trac bar, do i need this.. if not, would it benefit if i did..
would u recommend welding it on and if so, do u have to cut off old mount on axle? thanks!
if you have the jks you dont need it but its alot stronger than the stock mount so it wouldnt hurt...i also would say you dont need to weld it on because it bolts up really good..it bolts to the stock mount and the lower control arm bolt on the axle and there is also a u bolt that bolts around the entire axle..i have it and its a sturdy hunk of metal and there is no way its breaking off
alright sweet.. would anything get messed up if i used the jks trac bar and that? will the bar be to horizontal or is it fine.. reason im asking is i am up grading lift to TF 3in and it comes with the bracket and i have my jks and my stock trac bar so i didnt know which i should use it with the new bracket
I dont know what the JKS one looks like but I was running the superlift one and saw another guy rip his off so I upgraded to the TF one because it is a lot stronger. I would say if you are a avid wheeler then I would go with the TF one for sure.
your jks track bar will work fine just make sure you line it up with the right hole on the bracket...dont adjust your track bar when you put your lift and bracket on and the track bar should line up with one of the holes on the bracket..i use the second hole on mine with my 3.5 inch skyjacker lift...i think the first hole is for stock but im not sure
ok so i sort of have the choice to either use my jks or my stock trac bar with this bracket.. is it worth using the jks or should i just sell it and use the stock one? i dont see a difference in using one bar or the other..
