TF Rear Upper Control Arm Help
Old Aug 22, 2010 | 10:34 AM
Claydigger's Avatar
Default TF Rear Upper Control Arm Help
I installed these and started to torque the axle bracket end and noticed the bracket bending. Is the sleve inside the Arm supposed to crush and shorten as the bolts are tightened? Is this a defective joint?
I have attached pics of the drivers side(not tightened) vs the passenger side(still not torqued to 125).
ID:	82991   Click image for larger version
ID:	82992   Click image for larger version
ID:	82993   Click image for larger version
Old Aug 22, 2010 | 11:28 AM
Pluke the 2's Avatar
I dont think this is right.
PM Joe @ TeraFlex
Can you get closer on the pictures?
Old Aug 23, 2010 | 08:08 AM
TeraFlex's Avatar
Sponsoring Manufacturer
The inner ball/sleeve should be 2-5/16" wide, what do your measure in width?
Old Aug 23, 2010 | 09:17 AM
Claydigger's Avatar
Thanks Joe, I sent you an email.
Old Aug 26, 2010 | 06:46 PM
Claydigger's Avatar
Joe and TeraFlex Rock!
Their customer support is really good. They sent out a new set of arms and are sending a call tag for the arms I had a problem with. Joe answered several questions that I had too.
I finished the install tonight and took it for a little spin around the block. It definately needs better alignment than I am capable of. So, I have an appointment for tomorrow.
Old Aug 26, 2010 | 10:14 PM
There customer support is freakin awesome.
Lot's of e-mail correspondence between Joe I and he's a great guy.
They have won my customer satisfaction and I will buy from them again!
Old Aug 27, 2010 | 05:20 AM
HV's Avatar
HV
TereaFlex
