TF Trackbar bracket hitting TF Spring
Old Jun 4, 2010 | 12:11 PM
FlameRed's Avatar
Get the rock crawler wedges, I had the same problem. The real best answer is to cut your spring purches off, rotate and weld them back on the axle. But that's much more inovlved.
For the rear axle, you want to rotate the axle to get a good pinion angle. But that is the opposite direction of what the springs want.
Old Jun 4, 2010 | 01:55 PM
highoctane's Avatar
Originally Posted by dadgummit
Do you know How thick the wedges are? With the new 37's there is not too much room between the roof and the garage door.
I think I got like 1/2 to 3/4" lift max. Not much at all.
Old Jun 4, 2010 | 03:13 PM
Mark Doiron's Avatar
I got 1/2" additional height with the RK wedges. They fixed a similar problem on my Jeep.
Old Sep 30, 2011 | 06:45 AM
bbertram's Avatar
For me the bolt was hitting the spring, the nut is very close. There is to much thread so I put a washer on the head of the bolt and spaced it back and now it doesn't hit.....so far.
