TF vs OME
OME HD's should put you in the 3-3.5" range. (3.25" on my 4door with bumper/winch) A few 2-doors with no added weight are reporting 4".
From what I've read, the TF 2.5 coil kit should get you up into that same range. (they list 3" front 2" rear on their site)
I was talked into HD's up front and MD's in back. That compensated for the bumper/winch up front and set me level front to back. The MD's ended up sagging about 1/4", so HD's all around would have been better for me.
I ended up adding a 3/4" spacer up front and a 1" spacer in back, and am sitting level again.
x2. BTW, I gained 3 5/8 from the OME HD lift on my 4-door Rubi. That's with a Warn 8000 winch as well.
I truely hate when people tell others to use the search its "your friend" all this bs, search engines on forums are horrible, and its good to get a refresh every so often add others into it get new feedback, although i do hear u that question is asked at least 3 times a day and im still dyign to know the answer and ive read it at least 50 times
