TF vs OME
Old Oct 3, 2009 | 10:15 AM
silverfreak's Avatar
Default TF vs OME
from what ive read, the terflex 2.5" spring lift and OME lift with HD coils should yield about the same lift...am i correct?
Old Oct 3, 2009 | 10:29 AM
nthinuf's Avatar
OME HD's should put you in the 3-3.5" range. (3.25" on my 4door with bumper/winch) A few 2-doors with no added weight are reporting 4".
From what I've read, the TF 2.5 coil kit should get you up into that same range. (they list 3" front 2" rear on their site)
Old Oct 3, 2009 | 10:48 AM
are you using spacers up front with the OME to eliminate the rake? or did the lift eliminate it?
Old Oct 3, 2009 | 11:26 AM
nthinuf's Avatar
I was talked into HD's up front and MD's in back. That compensated for the bumper/winch up front and set me level front to back. The MD's ended up sagging about 1/4", so HD's all around would have been better for me.
I ended up adding a 3/4" spacer up front and a 1" spacer in back, and am sitting level again.
Old Oct 3, 2009 | 11:51 AM
O2Si's Avatar
I have the OME HD's in front and MD's in the rear with a AEV bumper and Warn 8000. It sits pretty level, much better than stock.
Old Oct 3, 2009 | 06:38 PM
Schantin's Avatar
Originally Posted by redx08
I have the hd coils front and rear with stock bumpers and mine sits close to level. Once i have rear bumper tire carrier and front bumper and winch it will be close to level. i also love the ride.
x2. BTW, I gained 3 5/8 from the OME HD lift on my 4-door Rubi. That's with a Warn 8000 winch as well.
Old Oct 3, 2009 | 07:30 PM
wildandwillin's Avatar
OMG do a damn search and get the answers you need. these questions are asked at least once a month....
Old Oct 3, 2009 | 08:06 PM
marcoseddi's Avatar
Default search!!!!
I truely hate when people tell others to use the search its "your friend" all this bs, search engines on forums are horrible, and its good to get a refresh every so often add others into it get new feedback, although i do hear u that question is asked at least 3 times a day and im still dyign to know the answer and ive read it at least 50 times
