Is there anyway to lock these down?
Old Oct 10, 2008 | 07:09 AM
Hellbound13's Avatar
Default Is there anyway to lock these down?
I ordered the shovel and axe hood mount...
My question is, can these be locked down somehow, so someone does not walk off with them? Is there a locking wing nut or something I could use?
Old Oct 10, 2008 | 08:47 AM
BlueAlgernon's Avatar
You have seen pad locks with the real long shank (U-shaped part)..Can you drill a hole in the plates that the bolts and wing nuts go through and use a pad lock like that? The lock part would be pointing up to the elements though but the only way i could see to get the shovel and axe off would be to rotate the lock part out of the way and un-screw the wing nuts. sorry if it's hard to understand... i wish i could draw it.
Old Oct 10, 2008 | 08:51 AM
RedneckJeep's Avatar
Can you post a bigger picture? I can't see what you're talking about.
Old Oct 10, 2008 | 08:59 AM
ok so i drew it.
Old Oct 10, 2008 | 09:01 AM
robin's Avatar
My question is, can these be locked down somehow, so someone does not walk off with them? Is there a locking wing nut or something I could use?[/QUOTE]
yes you can leave them at home locked in somewhere, somehow. do you honestly need an axe and a shovel everyday. I'm afraid to ask what you do for a living, do you work with tony?
Old Oct 10, 2008 | 10:36 AM
SMP_70's Avatar
Originally Posted by BlueAlgernon
ok so i drew it.
Nice graphic btw!
The only problem I see with that is someone could loosen the wingnuts enough to probably slip the tools out the side... unless the shovel had some sort of handle on the end.
I could have sworn I saw a large plastic screw-on knob that had a lock integrated into it somewhere. I'll see if I can find it again.
Old Oct 10, 2008 | 01:29 PM
Originally Posted by SMP_70
Nice graphic btw!
yeah you might need 4 locks or just wrap a bike cable lock round the whole thing. I don't know at this point I am just grasping at straws tryin to help out with an idea
