Is there a rule of thumb?
Old Mar 3, 2012 | 06:45 AM
vtwin17's Avatar
Default Is there a rule of thumb?
Got a set of new Nitto's, Max pressure is 35 psi. Installer inflated to 35 psi because of the TPMS. Yes it rides like a rock What should I set the pressure at? Is there a rule of thumb for setting pressure? Thx
Old Mar 3, 2012 | 07:06 AM
wayoflife's Avatar
JK-Forum Founder
Ideally, you should run them at a psi that gives your tread a good, flat and square footprint. With 35's, I find that something closer to 28-30psi will get you there.
Old Mar 3, 2012 | 07:25 AM
Ryan0260's Avatar
Agree. 28 lbs gives me a flat tread pattern and good ride with my 35" Trail grapplers
Old Mar 3, 2012 | 09:15 AM
OH9JK's Avatar
JK-Forum Ambassador
I use the old chalk method....
Park on level ground and aim front tires straight ahead.
Draw a line completely across the tread.
Pull ahead 2-3 tire revolutions or until the chalk starts wearing off.
If the chalk mark is worn off equally across the width of the tread, the inflation pressure is correct.
If the chalk mark is worn off more in the center than at the edges, as shown here, the tire is over inflated.
If the chalk mark is worn off more at the edges than in the center, as shown here, the tire is under inflated.
Old Mar 3, 2012 | 09:25 AM
Deere_Jeep's Avatar
28 psi with mine
MarvinMWJT's Avatar
As previously stated, 28-30 should be good. I actually run less in the back then in the front because of the weight distribution.
Old Mar 3, 2012 | 11:51 AM
vtwin17's Avatar
Thx for the responses
Old Mar 3, 2012 | 11:59 AM
Chronotripper's Avatar
Veteran: Marine Corp
Hmm...I'll have to air mine down and see how the ride feels. I'm currently at 35psi for my duratracs.
Old Mar 3, 2012 | 12:07 PM
joshsolo's Avatar
that a cool trick i need to remember that
Old Mar 3, 2012 | 12:13 PM
jbaskin28's Avatar
I'd agree with using this method. Its about the most accurate (for obvious reasons). When I picked my JK up, my front tires where at ~44psi and the rears where at ~38psi (255/75/17). I still need to chalk test them, but I'm running them all at 32psi and they seem to be doing great.
