is there such thing as tie rod flex with 37's?
i though my ball joints were going as my sterring wheel sways left to right ever so slightly on certain roads (not wheel balance as iv just done that and its not as violant) the manager as wheel works who drives a lifted f250 told me not to worry as this is just tie rod flex and is part of having a lifted vehicle on big tires. is this true or is it my ball joints going out?
I've never heard of that but if he's been wheeling for a long time then maybe there is. As far as your ball joints are concerned, a solid axle doesn't have a normal ball joint set up like an independent suspension system. It's takes A LOT to stress ball joints on a solid axle.
Some people haven't the slightest idea about steering and suspension! They sound like a shop that just makes them "look" cool. Functionality isn't some they sound too worried about.. Are there any other shops to take it to around there? I work at an independent repair facility in little rock, ar and a couple of my guys know more about lifts than most 4x4 shops! They helped me install my lift.
Take it to an alignment shop that understands lifted Jeeps and larger tires.
Originally Posted by jeeeep
never heard of "tie rod flex" but I had similar sway - turns out my toe in was just slightly off. So check you caster and with 37's your toe in should be anout 1/8"
i think u guys are right i need to take it to another shock and get a second opinion. they said that my tow is correct and they set my caster to 4.9 on the one side and a little less on other. i just went out and jacked the jeep up to shake the wheel and feel if there is any movement. there was non so that should mean the ball joints are fine. im now totally lost and figure maybe its just what running with 37s is like.
