THINGS TO KNOW WHEN GETTING 35s
Why would I have one or the other, there is not one answer for the 14 Sport model? What do I want after 35's go on?
Your window sticker will list what the gears are. If you don't have it, you can find an email address on the jeep website, Customers area. Enter your VIN and ask for a build sheet. If you don't want to do that, lift a corner, spin a tire and count driveshaft revolutions.
Whether or not 'you' want to regear will depend on which gears you have, and 'your' opinion of the power with 35's. Some with a 3.6 are ok with 3.73's, some are ok with 4.10's, some move up to 4.56 or even 4.88. There are plenty of threads talking about gearing, so don't make you decision based on a few replies in one thread, see what you think of the performance and do more research.
There has always been an option for gearing. 3.21 or 3.73 for non-rubicons, but, some early non-rubicons had the option of 4.10. All older rubicons were 4.10, but with the newest years, there is the option of 3.73 or 4.10.
Weaker isn't the right word. You might think of it as what you want your rpm's to be at certain speeds, or how much power you need to keep you at those speeds. (higher rpm = more HP/Torque). This is influenced by the tire size you move up to, how heavy your jeep has become, where you live, how you drive, your personal opinion, etc, etc. People at higher altitudes or who drive lots of hills might like higher rpm's, and people at sea level on board flat roads might get away with lower rpm's. Just depends on the variables.
Earlier in the thread, the FAQ's were mentioned. If you scroll down to the drivetrain section, you will find some great charts that are broken down by engine/transmission. Just plug some numbers in and see what you come up with. use measured tire heights, not mfg spec.
From all the posts, I'm assuming I should have a budget of at least $4500. I'll take it into consideration to see if I will be able to save that much and put on 35s! Thanks
Wow, you really don't need that much.
Here's how mine went:
$550 2.5" Teraflex coil kit with shocks, 3/4" spacers, and AEV control arm brackets & RE adjustable track bar (not necessary). Slightly used.
$1000 Gears.
$1250 5 - 35 tires (new).
$150 wheel spacers (this will depend on what you want).
So just under $3000.
