Think this is worth it?
Old Apr 29, 2013 | 06:15 PM
mattyk's Avatar
Veteran: Navy
Came across this online. Looks stout and is more affordable than other mods but is it really worth it for a dude that goes rock crawling once a month?
Thoughts and opinions?
www.artecindustries.com/JK-Front-Axle-ARMOR-KIT_p_309.html]Artec JK Front Axle ARMOR KIT[/url]
Old Apr 29, 2013 | 06:34 PM
Sgt Mack's Avatar
Hope so!
You have to weld it to your pumpkin which is cast steel. This is a big deal to do right.
matprovo's Avatar
Personally I think it's good cheap insurance. It's on my list
Old Apr 29, 2013 | 06:36 PM
mattyk's Avatar
Veteran: Navy
Originally Posted by Sgt Mack
Attachment 452615
Hope so!
I literally just threw the rancho front diff skid plate on this weekend. Will I still be able to use it with this?
Old Apr 29, 2013 | 06:57 PM
Sgt Mack's Avatar
No idea. Does it wrap around the top of the pumpkin? The truss just sits on top.
I deleted all my other photos on my phone so I only have these. The truss was the first step, welded on along with the lcas and C's.
Old Apr 30, 2013 | 02:26 AM
mattyk's Avatar
Veteran: Navy
no it uses the 5 bolts on the bottom half and also uses a u bolt to site behind the pumpkin on the DS. nothing ontop though
not the best pic but gives you a rough idea of what i mean
Old Apr 30, 2013 | 06:56 AM
Sgt Mack's Avatar
That should work fine. The truss is only on top.
Old Apr 30, 2013 | 07:21 AM
D_engel's Avatar
Yes, it is well worth the investment. A truss is the best option for beefing up a stock housing, and the artec armor set is the most complete kit for the JK. This is much stronger than the flimsy sleeves everyone tells you to weld in. Plus you maintain the option to move up to 35 spline shafts if you choose to do so in the future.
Old Apr 30, 2013 | 07:34 AM
Sgt Mack's Avatar
You can always add nitro sleeves ..... Pop right in and you can still run 35spline.
Old Apr 30, 2013 | 08:03 AM
Biggy's Avatar
I have nitro sleeves. I was under the impression you coudnt move up to 35 spline shafts.
