thinking of building SARGE's bumpers.
Old Nov 24, 2008 | 08:51 AM
  #31
VictorS's Avatar
Originally Posted by tbfreebird
The ones that Woods designed - are they available anywhere?
PM Woods directly. He is a sponsor on this site:
https://www.jk-forum.com/forums/show...t=woods+bumper
Old Nov 24, 2008 | 11:14 AM
  #32
tbfreebird's Avatar
Thnaks!!
Old Nov 24, 2008 | 11:55 AM
  #33
guybergeron's Avatar
Originally Posted by RedneckJeep
Are you talking about actually attaching the sheet to the bumper AND the tub? You cannot do that, as the two move independantly of each other. The tub is mounted to the frame with rubber mounts and will flex independantly of the frame. You are talking about making a valance panel. The proper way is to attach it to the tub, and run it just in front of the rear bumper, leaving a space wide enough to avoid contact with the bumper under any conditions. Valance panels are a body part, not a frame part.
hummm did not tought of that like that. thanks
Old Nov 24, 2008 | 12:01 PM
  #34
Originally Posted by ToyFamily
The front bumper looks like it is just the inner shell of the stock bumper cut down, it is VERY thin. As for the rear, as mentioned above it is just some 6" C channel, you may not need to weld the hitch on if you have a stock one (there is a crossmember it is bolted to), just 2 mounting plates down the sides of the frame rails.
Nick
well i think i will add some features like ... humm the front is gona be like the rear minus the midle peace but i whant to add some style to it .well i will see. i can add think i the futur.
Old Nov 24, 2008 | 06:04 PM
  #35
tbfreebird's Avatar
Any engineers out there can give advice on Aluminum C Channel vs. steel. Seems aluminum would be lighter - just not sure if it is strong enough. Metal depot has both - http://www.metalsdepot.com ...
Old Nov 24, 2008 | 06:36 PM
  #36
Stuka's Avatar
If you plan on off roading, do not use aluminum. If its for the street only, then good (thick) aluminum will be ok. Jeep started putting aluminum bumpers on FSJ's starting in 79. But it was quite thick.
The C-Channel I am most likely going to go with is 1/4" thick. Its 8.2 pounds per foot. So its really not that much weight.
EDIT: I am still working on measurements and such, when I get some plans drawn up I will post em here.
Old Nov 24, 2008 | 06:38 PM
  #37
alastair_ppcli's Avatar
those signals at the bottom are probably black out drive lights, most military patern jeeps have them to preform lo light no light moves on roads
Old Nov 24, 2008 | 06:41 PM
  #38
tbfreebird's Avatar
That would be great - thanks for the info
Old Mar 1, 2009 | 06:54 PM
  #39
jd8100's Avatar
Default c channel rear bumper
well boys i think i will see what i can come up with. cant really stand the stocker much longer. ill post pics on it soon
Old Mar 1, 2009 | 07:14 PM
  #40
i will be keeping a eye on that post.
good luck.
