> for those with 33's
Old Aug 3, 2010 | 09:18 PM
  #21
Ride_My_Jeep's Avatar
SO how much of a dog does a 2 Dr 3.73 with 33's become after converting from stock tires
Alfred
Old Aug 3, 2010 | 10:24 PM
  #22
Infinity's Avatar
I have to check on my gears, will probably have to jack it up and spin the tires / look at the drive shaft kind of thing.
Right now, I am leaning toward a Teraflex leveling kit, flat fenders, and 34's. If I can swing it, will add some skids or rocksliders (or both). Based on what I have read, I think that will all fit and hopefully not rub. It is kind of in between but should give me more clearance and a larger tire without being so tall as to upset the wife (or upset her too much).
Then it will be gears and lockers and, and, and, and......... you all know the drill it never really stops I suppose....
Josh
Old Aug 3, 2010 | 11:32 PM
  #23
thom1879's Avatar
Alfred
It's really not bad around town, but as for the highway...the overdrive off button will become your friend
Old Aug 4, 2010 | 12:05 AM
  #24
GRAVL's Avatar
The diff between 33's and 35's is more than just the tyre diam...
You don't need a huge lift either if you bump stop correctly and flat flares... think LOCG... which is not a bad idea for a shorty... they can feel quite tippy on the steep stuff but because of the shorter wheel base can have advantages on the trail with the belly.
But going 35's means you should really be thinking about doing some if not all of the following especially if you wheel it hard:
New drive shafts front and rear.
Stronger axles (especially the D30).
Re-gear to 4:88 for manual and 5:13 for the auto.
If you’re keeping the D30 you may want to gusset the C's etc.
Before you know it going up to 35's has just cost you an extra couple of grand...
Keep the 33's a good set of lockers, the correct gearing and some decent skids...
Pick your lines and you will get the JK a lot further than you others may think... practice is the key...
Old Aug 4, 2010 | 05:32 AM
  #25
It;s already pretty bad on the higways...lol
Alfred
Old Aug 4, 2010 | 09:05 AM
  #26
JeepNDad's Avatar
Originally Posted by NebRedrocker
Its not too bad with 33's auto and 3.73's. Nice on flat stretches of interstate but the hills get tough. Not bad in town though. I'm running 2 1/2 RC bb and 33 nitto mud grapplers.
Do you have any pics of your setup? I would like to see the look. Thanks
Old Aug 5, 2010 | 08:04 AM
  #27
PoorDad's Avatar
I run 33's and have found that I usually have to take a different line than guys with bigger tires, but I still am able to get through without getting stuck, most of the time. I make good use of my skids and rock rails! There is some advantage to 33's. Since my Jeep is my daily driver, and I commute 350 miles a week, I get a little better mpg than if I had 35s or bigger, and they are lighter. I only have a 2 1/2" spacer in the front to compensate for the weight of my winch and front bumper. Otherwise, my suspension is stock.
Old Aug 5, 2010 | 08:23 AM
  #28
Joisey's Avatar
Alfred
you saw mine alfy, i have 3:21's did it look like i dogged at all?? I yanked that knocked down tree the hell out of the trail and made it over everything that all the other jeeps did. 33's a leveling kit and qd's would be perfect for what your are going to be doing with your jeep. remember a stock jeep is more than capeable.
Old Aug 6, 2010 | 02:15 AM
  #29
Thats the same setup i am kind of looking for
Not exactly sure what qd's are though
BTW, did ya get my PM on your 33s?
Thanks
Alfy
Old Aug 6, 2010 | 09:54 PM
  #30
Joisey's Avatar
yea homes, ran into some expences 35's at the end of the month, as soon as i get them the 33's are yours.
