Thoughts on shimmy
Old May 3, 2016 | 07:50 PM
phljeeper's Avatar
Default Thoughts on shimmy
I have a 2015 two door with 2.5" Rock Krawler max travel with 35" trail grapplers. Rides great at city speeds and on the highway up to about 65. At 70 I get a shimmy. It feels like a tire balance issue but I have just had them re balanced and all good. Thoughts on what to check next?
Old May 3, 2016 | 10:27 PM
sa29560's Avatar
Work your way up. Check ball joints, tie rod ends, and drag link ends, track bar at frame and axle, play in unit bearings, bad u joints, torque on all bolts in control arms.
You running stock drive shaft?
Old May 4, 2016 | 12:59 AM
Biginboca's Avatar
Swap your front and rear tires. If the shimmy changes then you know it's the wheels/tires. If it doesn't you need to look at driveline and steering.
In my experience any speed sensitive shimmy or wobble has always been a tire/wheel issue
Old May 4, 2016 | 01:36 AM
nthinuf's Avatar
Go up to the JK Write-Ups area. There is a diagnosis thread by Planman stuck right to the top...
Old May 4, 2016 | 02:59 AM
kjeeper10's Avatar
Vet Army
Originally Posted by Biginboca
Swap your front and rear tires. If the shimmy changes then you know it's the wheels/tires. If it doesn't you need to look at driveline and steering. In my experience any speed sensitive shimmy or wobble has always been a tire/wheel issue
X2 (10 char)
Old May 4, 2016 | 01:09 PM
phljeeper's Avatar
Originally Posted by kjeeper10
X2 (10 char)
Thanks guys. I know the planman writeup on wobbles. I have checked everything and all tight and good. The jeep only has 8k miles. I will try tires again.
Old May 4, 2016 | 01:25 PM
Smudgeontheglass's Avatar
I have a 2012 two door with a 2.5" Rubicon Express lift with 35" trail grapplers. I didn't have castor correction when I first lifted the Jeep but it drove perfectly fine with the stock BFG KOs. When I upgraded to a used set of the Nittos it had a very noticable wobble at around 70-80km/h. I upgraded my track bars to Adjustable JKS track bars and that helped a lot with the "flighty" steering feeling but I still had the same wobble. I did a 5 tire rotation and had no change in the wobble at that speed.
This spring I got gussets and a truss installed and to save some cash on the alignment I got some RE Geometry correction brackets. That moved my castor back to the 5-6 range and corrected the wobble problem completely.
I will eventually get better control arms but for now the brackets help a lot.
Old May 4, 2016 | 03:13 PM
phljeeper's Avatar
Originally Posted by Smudgeontheglass
I have a 2012 two door with a 2.5" Rubicon Express lift with 35" trail grapplers. I didn't have castor correction when I first lifted the Jeep but it drove perfectly fine with the stock BFG KOs. When I upgraded to a used set of the Nittos it had a very noticable wobble at around 70-80km/h. I upgraded my track bars to Adjustable JKS track bars and that helped a lot with the "flighty" steering feeling but I still had the same wobble. I did a 5 tire rotation and had no change in the wobble at that speed. This spring I got gussets and a truss installed and to save some cash on the alignment I got some RE Geometry correction brackets. That moved my castor back to the 5-6 range and corrected the wobble problem completely. I will eventually get better control arms but for now the brackets help a lot.
Thanks. I do have a full set of Rock Krawler control arms and have the caster dialed in to about 6. I hope to try rotating and see if that helps. The tires have about 6k on them and have been rotated once.
