Thoughts on these PR44 set ups
I'm not condemning manufacturers. I'm saying there is no evidence to support superior quality, and certainly not enough to warrant 4x the cost. I think it is useful to others to hear a different perspective. Why not save someone $600 by telling them the value isn't there? I've bought most of the high end stuff and found out it was no better, or only marginally better than low cost parts. It is similar to the law of diminishing marginal utility. OEM ball joints are good. Call it a score of 100. $200 joints are a little better. Call it a score of 115. $600 joints are say 120. Spending $400 for that extra 5% is a bad use of $$$.
Yeah, So I have a cool 226,000 miles on my 09 JKU.
I run 35s on the d30, all stock minus a re-enforced track bar bracket.
I've only had to replace my ball joints twice. Once at around 70k due to death wobble.... They were not the cause, but an effect of the wobble. The wobble damn near tore everything off of the axle. So, they (dealer) ended up replacing the whole axel housing and did the ball joints too.
The second time was at around 184,000 miles... They were just worn out and just started to have a tiny bit of play. So, boom... new OEM ball joints.
I've got nothing bad to say about the oem parts... If you abuse anything, it's going to break!
This is the perspective I am trying to provide. I'm not pushing product, I'm doing the opposite. Some things are worth spending money on, some things aren't. People want to buy stuff, it is human nature to acquire. Everyone says the OEM ball joints are weak, so everyone goes out and upgrades. It isn't the joints themselves, it is the joint size and trying to run large tires. People severely underestimate the quality of OEM parts. Chrysler does a lot of material engineering. They don't want to warranty ball joints on every Jeep. No one can make a bushing to compete with what is in a stock control arm. Does the use of plastic in an OEM joint make it inferior? I don't know. Apparently we can 3D print working assault rifles out of plastic, so why not a ball joint?
As far as oem quality....that's why I went with the new TF Alpine adjustable arms due to the oem clevites style ends.
That coupled with synergy fixed lowers and their DD bushings will last forever and be quiet.
I netted almost 5" lift along with my 37's will play hell on any BJ'S eventually. I will likely either go Napa gold or TF when BJ'S need replacing.
Sent from my SM-N920T using JK-Forum
FWIW, I went thru my oem balljoints in less than 15k (on stock tires), two sets of synergys with ~20k each, and I'm currently running dynatracs which are okay for now @12k miles. We'll see if they're worth the 500 bucks they go for.
Looking a couple of different PR44 configurations and would like your input. Which configuration would you go with and why (note gearing too please)? First here is info on my rig and uses:
- 2013 Jeep Wrangler Unlimited D30 front axle with 3:73 gears and factory limited slip differential
- 2.5 Rock Krawler Max Travel Kit with Rancho 9000 shocks. Kit includes their lower control arms (front & Back) and rear trac bar bracket
- Synergy front trac bar with their sector shaft brace kit
- Synergy steer stabilizer relocation kit (bracket that goes over factory axle side trac bar bracket along with clam on tie rod). Allows steering stabilizer to be up higher.
- Currently running Goodear Duratrac 315/70R17. May go to Nitto Trail Grapplers 35x12.50 in the future (heavier tire).
- My rig is my daily drive and see a lot of and mostly pavement time. Mostly day to day in town driving and a few road trips from time to time. However, I would like to get it where it's good for that but can handle some decent off-roading as well. Terrain around here is mostly rolling hills, muddy trails with ruts, however, we do have an off-road park about 2hrs away that offers some rocks.
- My rig does have some weight to it with front bumper & winch, rear bumper, Ace Sliders with Rubi rails, and skids.
Option A
PR44 set up to use factory knuckles, brakes, factory track bar location, and connect to factory front drive shaft
New ball joints (either Synergy or dynatrac thru the free with purchase of housing offer)
4:56 or 4:88 ...thoughts on gearing?
RCV shafts
ARB locker with twin compressor
Rear to get gears and new axle shafts (ten factory)
Option B
RCV shafts
Detroit Truetrac
New front drive shaft with cost savings from not getting ARB with compressor.
Option C
RCV shafts
Eaton E-Locker
Maybe new front drive shaft with cost savings from not getting ARB with compressor.
Option A
RCV shafts
Option B
RCV shafts
Detroit Truetrac
Option C
RCV shafts
Eaton E-Locker
To give MAGOO some feedback on his options, here are some thoughts.
As for gear ratio, I recommend the 4.88 ratio. In my humble opinion too many folks shy away from high numerical ratios. JK’s are great 4x4’s, but when you add a bunch of weight, tires, and lift they get sluggish. An engine that spins too slow is just as likely to cost you fuel as one that spins a bit too fast. The lift creates more wind resistance, the tires create more drag on the pavement, and who doesn’t want a lively, responsive ride? The bumpers, winches and other stuff adds more weight to haul around.
If you go to bigger tires (35-37) you want the Jeep to upshift and run in OD, not constantly downshift for headwinds and minor grades.
Engine RPM that is fast or slow is subjective. But we know the manufacturer did everything possible to get a low MPG to meet their CAFE numbers. Therefore I look at my known RPM and MPG before tires and lift, and use that as my baseline. The Jeep will need more RPM to overcome the additional weight, wind, and tire drag. You should have your new ratio yield a higher RPM than stock.
We like ARB’s. Installed thousands. The new Eaton 44 E-locker is also very durable, and a good choice. It boils down to personal preference between air or electric.
With respect to the necessity of a ProRock 44 and ball joints, none of the aftermarket parts for your Jeep are really necessary, but you increase the risk of failure when you add vehicle weight, larger tires and more engine power. You’re simply going beyond what the stock components were engineered to withstand. We add items to our vehicles to contribute to the performance, durability, reliability, and owner satisfaction. Can you drive the Jeep without needing a stronger housing? Absolutely! Will you bend a housing like thousands of other JKU owners have? I’d say there’s a pretty good chance. It’s your money; your decision. What’s your peace of mind worth when you head out into a remote area on your own?
I’m sure there are guys that have more experience than I do. I respect everybody’s opinion, even when it doesn’t agree with my 36 years of Jeep, truck, 4x4, drivetrain, suspension and chassis experience. If some folks don’t think a ProRock 44 is worth the money, I’m glad they didn’t buy one. We created the product for good reasons, and happily most folks agree with those reasons. In fact, there are more ProRock 44s under Jeeps today than all other competitors combined. Here is a link that compares the ProRock 44 to other options if you want some more facts to ponder. http://www.dynatrac.com/downloads/Pr...20FAQ_revK.pdf
We also have some very high quality, US-made axle shafts to offer you for the 44 rear, and the front ProRock 44. Our ball joints are the only 100% US-made ball joint for your JK. More on that here: Why Dynatrac? Ball Joints Are Better | Dynatrac Tech Info and News
We don’t care for imported stuff. Won’t get started on that here.
You bet Kjeeper10. The new Dynatrac JK44 Axleshaft Kits for JKs was engineered to fill a gap in strength and price between imported aftermarket axleshafts and RCVs. The fronts are made from high-strength 4340 chromoly and the come with new 1350 U-joints. They fit stock Dana 44 axles and our ProRock 44 without any modifications.
The first version of the rear JK44 Axheshaft Kits (available now) are larger in diameter, going from 32 to 35 spline, so they are perfect for someone who is interested in upgrading the rear differnetial and the rear axleshafts at the same time. These have a deep heat-treat for optimum resistance to twisting without making them too brittle. We developed unique, billet steel retainers for improved installation and serviceability. The rears come with new bearings and seals.
Both front and rear axleshaft kits are Made in the USA.
You can post more specific questions if you have them, and you can see more info here: Axleshaft Kits
