Tips? Bushwacker Flats Install
Old Jun 15, 2011 | 09:53 AM
TURTLECON's Avatar
Default Tips? Bushwacker Flats Install
Just got the Bushwacker Flat Flares for my JK 4-door. I'm going to install myself. Anyone got any tips for me?
I've heard it takes awhile & to plan on 6-8 hours to do them all. Ive read through the step-by-step instructions & it seems that marking & trimming the liners is a big PITA.
Old Jun 15, 2011 | 09:55 AM
rinkishJK's Avatar
what ive read is u want alot of extra plastic rivets that hold the liner to flare on the edge.. i do not own these, nor have i installed any though....
Old Jun 15, 2011 | 10:14 AM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
This should help
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Jun 15, 2011 | 10:21 AM
09Jeep4X's Avatar
The only problem I had during the install of my flares was the nylock nuts seized on the bolts, which caused some problems. I started putting a little oil on the ends of the bolts before threading the nuts and problem resolved.
Old Jun 15, 2011 | 11:02 AM
sick jk's Avatar
I just installed the flat fenders on my rig. I didn't use any more rivits than what came with the kit. The install was easy but took about 6 hours. Very time consuming. Marking and cutting the the wheel well plastic was simple. I used a sawzall and it worked great. Just take your time and follow the instructions. I am super happy with them. Good luck
Old Jun 15, 2011 | 11:06 AM
Danny4652's Avatar
I just put mine on last week. Most important thing is to play close attention when cutting inner fender Wells for re-install. If you don't do it right, it will look like sh**.
Old Jun 15, 2011 | 11:22 AM
TURTLECON's Avatar
Thanks for the tips & the link! The write-up was pretty helpful & seemed to simplify the original instructions. It looks like they come with the plastic retainers (I'll have to double-check the bag when I get home) so ruining or losing a few of the stock clips shouldn't be an issue. If not, I guess I could buy extras to be on the safe side, but not sure where I could order these or what specifically to call them.... "plastic fender clips" maybe?
Old Jun 15, 2011 | 11:27 AM
TURTLECON's Avatar
Looks really good!
Old Jun 15, 2011 | 11:32 AM
jeep2007's Avatar
Straight forward install. Cutting the inner flares correctly is a must. Side note:if one of the lights doesn't work black to black/white to white, reverse the wires. No big deal.
Old Jun 15, 2011 | 04:08 PM
Mad-Hatter's Avatar
x2 on both of these. Check the light wiring early in the process so you know if they are reversed or not. I went and got more hardware altogether. I tested the nuts and bolts with oil since I had heard bad things prior too, and half of them seized on themselves even though I was being gentle. all new bolts and no problem. cutting the liners is easy, just do like they say and you'll be fine.
