Tire Choice
Old Mar 2, 2011 | 06:24 AM
AZEnder's Avatar
Default Tire Choice
Need a bit of advice here.
I really want a set of Duratracs as I hear they are the shizzle! However I have the 18" Sahara wheels which I want to keep. The duratracs only come in two sizes for an 18" wheel. The size I want and think we will work LT275/70R18E1 125Q B. I do not have a lift currently but I am willing to put up with some minor rubbing until I can put a lift on her.
I did read the Answers to the Questions Every Newbie Has Tires and Wheels section but there is nothing in there about 18" wheels. To me the LT275/70R18E1 125Q B seem pretty close to 285/70R17 for the 17" wheel.
Thoughts, concerns?
AZEnder
Old Mar 2, 2011 | 06:28 AM
cosmec's Avatar
Thoughts, concerns?
AZEnder
That would probably measure out to under 33 inches as duratracs run small.
Old Mar 2, 2011 | 06:50 AM
AZEnder's Avatar
Thanks I feel better.
Old Mar 2, 2011 | 07:28 AM
AZEnder's Avatar
What will I need spacers for?
Old Mar 2, 2011 | 07:55 AM
Spartangreen's Avatar
Here is a pic on the Sahara rims.
275/70/18
They measure 32.625" @ 35psi. Measured after leaving the tire store.
I installed the lift/wheel spacers before getting the tires. No rub.
Old Mar 2, 2011 | 08:08 AM
BlackRockBurner's Avatar
I ran 275/70R18 Cooper STT with Gladiator rims and no lift but had to adjust the steering stops due to rubbing on the lower front control arms. Suggest Spidertrack spacers. Not only will this fix rubbing, but you will like the wider aggressive look and you benefit with lateral grip from the wider track.
Old Mar 2, 2011 | 08:16 AM
Discount Tire's Avatar
Sponsoring Vendor
Originally Posted by TheDirtman
Get a 16" rim and tire. the 18" tires are expensive and you can find a 16" rim and tire for about the same amount as just the 18" tire this will also allow you to correct the backspace issues so you wont need spacers.
I'm with Dirtman on this one. You may want to look into some 16" or 17" options. Upgrading your wheels now will certainly make things easier in the future if you plan on going with a tire larger than 33".
Old Mar 2, 2011 | 10:40 AM
AZEnder's Avatar
275/70/18
Are your duratracs really noisy? I am getting ready for a 12-13 hour drive to Colorado.
Old Mar 2, 2011 | 01:00 PM
I dont notice any additional noise, but I don't hear real well.
Old Mar 3, 2011 | 12:28 AM
Normak111's Avatar
275/70/18
What size and kind spacers are you running. I want to get a 33" tire on my 18"s and i want to powder coat them flatblack.
