Tire Choice
no offense to the 1.5" wheel spacer guys, but I really think adding a spacer vs getting the correct backspacing wheel is a bad idea for these already longer axles on the JK's.
your extending the axles 3" more which can cause stress on the axles/housing if you wheel hard. But if you are a mall crawler then F#$% it...Spacers would be ok in that case.
Do it right the first time and never look back.
Originally Posted by erpeden
I am no expert but cannot see any difference on the axle load by using spacers or different rims with less backspacing either way you are extending the wheel base
Its my opinion and it could be wrong, but It could be right also.
my thoughts.... the rim is one piece supporting a tire, spacers are another add on and possible weak point plus extra weight. Correct backspacing rims seem to me to be the right way to go for a solid dependable situation.
Need a bit of advice here.
I really want a set of Duratracs as I hear they are the shizzle! However I have the 18" Sahara wheels which I want to keep. The duratracs only come in two sizes for an 18" wheel. The size I want and think we will work LT275/70R18E1 125Q B. I do not have a lift currently but I am willing to put up with some minor rubbing until I can put a lift on her.
I did read the Answers to the Questions Every Newbie Has Tires and Wheels section but there is nothing in there about 18" wheels. To me the LT275/70R18E1 125Q B seem pretty close to 285/70R17 for the 17" wheel.
Thoughts, concerns?
AZEnder
Thoughts, concerns?
AZEnder
I'm planning on 18" aftermarket wheels with 275/65/18 duratrac since I will not be doing a lift and i want to avoid them sticking out past the fenders.
Have you done a price comparison between the 16-17" tires vs. the 18"? In some cases it can be as much as $100 more per tire, especially in the 35" range. Plus, if you have to buy spacers to accommodate a wider tire, there's another $150-300 or whatever they cost.
I have 315/70/R17 Duratracs, and for what it's worth height wise, I'm anywhere between 34" and 33.25" depending on what psi I'm running, and this is on a 9 inch rim. The height of these tires did fit under my stock unlimited suspension....no room for flexing, but will work, so your 275/285 height should be fine.
my backspacing is 4.5" in lieu of the stock rims at 6" or whatever it is....and I have zero issues with rubbing.
As far as the question above regarding road noise, I've heard none. Maybe with the top and doors off on the hwy, there might be a slight humm, but it's enjoyable.
But If I remember right, the 275/65/18 may be the same diameter, but are significantly wider than stock.
After reading a ton of threads on tires I've decided to go with the 315/70/17 Duratracs. I don't plan on wheeling all that often, my Jeep is my DD, but we do have a cabin in South Lake Tahoe I visit often (snow).
As for the wheels - I went with 17" XD Addicts. Got them on eBay for about $150 a piece. The way I see it, when I sell my stock Rubicon tires and wheels it should almost cover the entire purchase price of the Addicts.
No spacers, a cool looking wheel (In my opinion), at almost no cost to me =
FWIW I went the lift route, but from yout original post I think you are trying to avoid that....
