Tire Help
Old Aug 5, 2014 | 06:51 PM
KingTaco5's Avatar
Default Tire Help
I have a 2010 4 door JK and i plan on putting 35 inch tires on. i was going to go with 33's but i know I'm going to want bigger but i've been looking around a lot to figure out what changes i would need to make (besides a lift) to get it done. I've also read a lot about gas MPG change. some say its not a big change, others I've read its a huge change. So, my question for that is how much of a change is it? thanks.
Old Aug 5, 2014 | 06:57 PM
Waldo_88's Avatar
It all varies... Your driving habits, your gearing, what tires you choose, performance upgrades, and your area (Hilly or flatlands)...I didn't notice much of difference when I had my 35's. A little slower off the line and passing people on the highway became strategic, but fuel mileage wasn't but a few MPG's off. It's well worth it in my eyes.
Old Aug 5, 2014 | 07:14 PM
rozzman10's Avatar
Went from stock tires to 35s. From 21MPG to about 17MPG, if my math is right. I didn't buy my Jeep for mileage though. I have 3.73 gears and as long as the roads are somewhat flat it stays in overdrive, but running up and down hills it is always changing gears. If you think you want 35s, get them. Or every time you see a set of them you'll be sick haha
Old Aug 5, 2014 | 07:53 PM
davison0976's Avatar
This is how my mpg changed with each modification. Please note I have 33" tires, not 35"s.
In case the pic is not large enough to see clearly, adding 1.5" lift took away 1.5mpg. Then adding 33"s took away additional 2mpg.
Notice, however, that because circumference of the tire is larger in 32->33 transition 0.5mpg will be "lost" due to that factor. 32->35 is a 9.1% difference, so figure 1.5mpg less only because you travel more per same number of shaft revolutions. So, your ODO shows you traveled less than you actually did. So, whatever mpg you get with 35", add about 1.5mpg to get the actual mpg, unless you changed computer settings to reflect larger tire diameter.
Name:	mods and mpg.jpg
Old Aug 5, 2014 | 07:58 PM
LDK59's Avatar
I have a 09 JKUX auto w/3.73 gears on 35" BFG All Terrain KOs ... I get ~18 hwy / 11 city
(i run with O/D disabled)
I (like most others here) didn't buy a Jeep for fuel mileage...
Old Aug 5, 2014 | 08:20 PM
Mountain Man Tim's Avatar
if you have 3.21's or god forbid 2.73s and you get 35s the next thing youll get is a regear.
Old Aug 6, 2014 | 01:32 AM
carlojp's Avatar
For tires, you can get Trail Grappler's for that size. One of the best all around tires out there.
Old Aug 6, 2014 | 02:58 AM
jadmt's Avatar
JK-Forum Ambassador
well luckily they did not put 2.73's in any wranglers.
