Tire question?
Old Oct 2, 2012 | 05:09 AM
Punisher8808's Avatar
Default Tire question?
I am going to go with a 3.5 inch lift for my 2013 two door JK. I have been told by many people that I should run 33" tire and that if I go with 35"s I will have to re-gear. So my major question is this true cause I want 35's?
Old Oct 2, 2012 | 05:25 AM
My current gearing is 3.73.
Old Oct 2, 2012 | 05:33 AM
popo343's Avatar
You should post this in the Modified section. Is it stick or an auto. You may have to regear with 35s. There are a few members saying 4.56s
Old Oct 2, 2012 | 05:41 AM
TaylarsJK's Avatar
I have a 4" and 35s with an auto tranny and 3.73 gears, have noticed a little power loss, gas mileage on the highway is crap
Old Oct 2, 2012 | 07:01 AM
2013 two door auto! 3.73 gears.
Old Oct 2, 2012 | 07:12 AM
Ok what's the approximate cost of going to 4.56 gears?
Old Oct 2, 2012 | 07:22 AM
JK4x4wrangler's Avatar
I have looked into it near me, the parts can run $400-$600 and it'l be around $1200 for labor. thats what I have gotten asfar as quotes near me. I have also been told it is VERY easy to mess up so unless you really know what you're doing you should not try it yourself
Old Oct 2, 2012 | 07:36 AM
WhtMtJK's Avatar
I would think you would want to re-gear. I am running 4.10's and 35's and could not imagine 3.73's especially if your going to do any off-roading. If it's just going to be a Mall Crawler you might be OK but otherwise I would plan on the added expense.
Old Oct 2, 2012 | 08:42 AM
newbiejeeper's Avatar
you will need new drive shafts as well since you are an auto two door. lifting it over 2 inches will cause the drive shaft boots to rub on the transmission skid.
Old Oct 2, 2012 | 09:31 AM
PharmNip's Avatar
33s are a lot bigger than you think. Mine are being put on tomorrow and to look at those compared to stock is a HUGE difference. I wouldn't go 35s without re-gear. Also need to think about stress on the axles, ball joints and brakes. If you have the $$$ to deal with the inevitable follow-up mods, go 35s.
