Tire Rub
I have 3.5" RE lift and I am rubbing in the front at full flex. I am running 33" tires on 3.75" BS 15X10 wheels. I would post a picture, but the camera operator was suction cupped to the seat from ass pucker. I know fender chopping will fix this, but if I go to 35's or bigger I will be right back here again. Any ideas?
Then add more lift...
If you think about it, your options are Smaller Tires, More Lift, Bumpstops, or Flats.
Smaller tires kinda defeats the whole purpose of lifting and ground clearance.
More lift costs more money to fix the issues created.
Flats are a temp fix, as you will have the same issue when you go to taller tires.
More bumpstop will only limit the uptravel. --> Downtravel is what you want.
So, choose your poison.
My opinion? Bumpstops.
