Tire rub (inside)
Old Aug 9, 2010 | 10:38 PM
Red Dog's Avatar
Default Tire rub (inside)
OK I have a lift with 35” tire. They are rubbing on the inside just a little sometimes and I know if I could get them out another .25” I would be golden. I was looking at the small spacer and then might need longer studs. So I am hoping that some body out there can give me some help solving my problem.
Old Aug 9, 2010 | 10:44 PM
nthinuf's Avatar
Faq's:
Q: Are wheel spacers safe to use or do they cause extra stress on your axle or wheel bearings?
A: High quality wheelspacers, the kind that bolt up to your axle first are no more dangerous or cause any more stress to your axles then would a wheel with less backspacing. Anyone who tries to tell you otherwise doesn't know what they're talking about and I have yet to hear a single good or specific explanation as to exactly how they are worse. Just to be clear, the cheap-o spacers (the kind that you can get at PepBoys and are sandwiched between your wheel and axle using the existing wheel studs) are in fact EXTREMELY DANGEROUS. These cheap-o spacers leave little thread for your lug nuts to hold onto and can fail. DO NOT USE THESE!
Get a good 1.25-1.5" spacer (with two sets of bolts)
Or
Adjust the Steer Stops
http://project-jk.com/jeep-jk-write-...top-adjustment
Or
New rims with the correct backspace...
Old Aug 10, 2010 | 02:14 AM
JPop's Avatar
Good advice here, adjust the steer stops, new wheels or spacers which are going to need to be in the 1 1/4 - 1 1/2" range.
Old Aug 10, 2010 | 11:44 AM
Red Dog's Avatar
I had the 1.5“ spacers on and it was over kill. I take them off and it rubs a little. I only need .25”. May be I will get some .75’ spacers. I was looking for an easy and inexpensive fix to my problem, as we know that hardly ever happens.
