tires
Old Sep 6, 2009 | 09:22 PM
dmick33's Avatar
Default tires
What are the biggest size tires I can run on the stock 16"
Old Sep 7, 2009 | 05:52 AM
jeepmedic's Avatar
I ran 285/75/16 with no problems. Still run them with 2.5" OME lift and it looks alright.
Old Sep 7, 2009 | 08:37 AM
srtklr's Avatar
I run a 315/75/16 bighorn on the stock 16" steel wheels. Seems to do good so far.
Old Sep 7, 2009 | 08:38 AM
Outdoors's Avatar
Thumbs up
Originally Posted by jnorton1
Any pics on stock ?
Yep, here's mine before my lift was installed..
The tires were the first upgrade I did.
Have fun in your upgrades..
Old Sep 7, 2009 | 11:36 AM
AK4Dave's Avatar
So you guys aren't rubbing at all with the stock BS of the wheels...???
Old Sep 7, 2009 | 11:46 AM
srtklr's Avatar
With that question I am assuming you are asking what is the biggest tire you can put on a stock wheel with out any mods? No lift or anything? With that being said I'd say a 265/75/16 is going to be the biggest with out any fear of rubbing. A 285 will fit and depending on how tall and wide the tire actually is it may or may not rub off-road. If your just talking on-road I would say a 285 would be ok.
Old Sep 7, 2009 | 12:29 PM
nthinuf's Avatar
The FAQ's are generally a good place to start.
https://www.jk-forum.com/forums/show...74&postcount=3
Q: What is the biggest size tire I can fit on my stock Jeep JK Wrangler?
Q: What is the biggest size tire that I can I fit with a 2.5" Budget Boost?
Q: What back spacing will I need on my wheels in order to clear 12.50 wide tires?
Etc...
With no lift, no wheel spacers and no trimming, a 33x10.50 (or metric equivalent) is as big as you'll want to go.
Old Jun 21, 2014 | 07:15 AM
brucear's Avatar
Default tire size
so what size of tire do you have
