tires
Old Nov 18, 2007 | 04:18 PM
postwheel's Avatar
Default tires
does any company make 305/75/16 size tires..
Old Nov 18, 2007 | 04:41 PM
armycop's Avatar
I couldn't find one. Just 305/70/16 (33") and 315/75/16 (35")
Old Nov 19, 2007 | 12:09 PM
Discount Tire's Avatar
Sponsoring Vendor
Corrrrrrrrrrrrrect! no go on the 305.75.16
Old Nov 19, 2007 | 05:35 PM
Turk's Avatar
"Aspect Ratio is the ratio of the height of the tire's cross-section to its width. On our example, 65 means that the height is equal to 65% of the tire's width."
The diameter of the tire (75) is probably the same as the 70 in the wider tire. It has a lower number because the aspect ration changes cause the tire is wider. The sidewall is probably exactly the same between the 70 and 75 in your example.
Make sense?
P.S.: I just bought 305/70-16 BFG AT KO's - - awsome tire and almost 12.5 wide.
Old Nov 19, 2007 | 07:02 PM
Rebel Heart's Avatar
If I want a 17" rim with 35 tires. What numbers do I want?
Old Nov 19, 2007 | 07:11 PM
armycop's Avatar
Try 315/70R17 or just 35x12.50R17
