Tires
Old May 9, 2012 | 01:00 PM
Mark73's Avatar
Default Tires
Will 295/75r 16 BFG fit my stock 16 rims ? And I'm wondering width of stock rim ? I have 265/75r16 BFG on now. Thanks for any input
Old May 9, 2012 | 01:14 PM
Matthewd5's Avatar
I'm not a tire expert but I've been doing a ton of reading on the subject...
You have 16" wheels, 75 is the width of the rim/tire is 75
So it should fit rim wise
The fit issue would probably be whether or not you had the clearance in the wheel well for the height/diameter of the wheel and if it will rub when you turn
Matthew
Old May 9, 2012 | 01:28 PM
shook's Avatar
No, that's not quite right.
295 is the width in MM and 75 is the width to height aspect ratio, 16 is the wheel diameter. That makes them rougly 33.4" x 11.6"
Yes, obviously they will fit the wheels but you would need to be worried more about weather or not they will rub. Do you have a lift at all?
I'm thinking you will need spacers to keep them from rubbing at full turn.
Old May 9, 2012 | 01:46 PM
RockChalk-JK's Avatar
I'll second that.
Old May 9, 2012 | 01:56 PM
JKRIDER07's Avatar
Default tires
I have 285/75R16's on stock steelies on my JK and there is no rubbing at all. So you should be okay. I have a 2" lift also.
Old May 9, 2012 | 01:57 PM
Mark73's Avatar
Yes they r 33.4 and I have a lift 3inch . Just was not It Sure if they were to wide . For these rims not sure what width they r 7inch maybe? Soon I will by a wider rim with 3.75 off set but am hoping I can use stock ones for now
Old May 9, 2012 | 02:06 PM
JKRIDER07's Avatar
Default tires
They show 8.7" sidewall width. Mine are 8.4" on my 7" rims mine are good.
