Tires 285/75/17 actual height
Old Apr 8, 2012 | 09:53 AM
BDH's Avatar
BDH
Default Tires 285/75/17 actual height
Please post me picks of your JK with 3.5 lift and 285/75/17.
I also would like to actual mesurments (ground to top of tire) of the 285/75/17 and the tread width of the same tires preffreably TOYO MT'S.
Im looking for tall (34-35 tires) but skinny (11"-11.5") wide.
Old Apr 8, 2012 | 06:37 PM
Marks-JK's Avatar
Here is a web site I use to compare wheel sizes. A 285/75/17 would be 33.9" tall and 11.2" wide
http://www.rimsntires.com/specs.jsp
Last edited by mkjeep; Apr 8, 2012 at 06:45 PM. Reason: no non sponsor clickys please
Old Apr 9, 2012 | 07:27 AM
etracy21's Avatar
I just put these size tires on my 2012 Unlimited Sport. I only have a 2.5" skyjacker lift and I wish I would have went a little bigger. Mine are mounted on a 9" wide wheel so the actual height of the tires is slightly shorter than the height of the tire unmounted.
EDIT: Went and snapped a quick photo of spacing for you
Old Apr 9, 2012 | 10:59 AM
fifthconspiracy's Avatar
I have Nitto Trail Grapplers 285/75/R17 on a 17x8 rim. I too wanted to keep the tires narrow.
They measure just a hair under 34" tall at 29psi.
Here's mine. Teraflex 4" lift with the tires. Sorry, the only pic I have handy at the moment.
Cheers!
Paul
Old Apr 9, 2012 | 06:45 PM
BDH's Avatar
BDH
Default Width
fifthconspiracy,
How wide are the tires (tread width)??? Do you like the look with your 4 inch lift?
More pics from front, read and side if you could.
Attachment 301659
Cheers!
Paul
Old Apr 9, 2012 | 07:54 PM
jefemente's Avatar
Toyo M/T 285/75/17 on a RK 2.5 which netted me approx. 3.5-4" in the front.
Old Apr 9, 2012 | 07:57 PM
jefemente's Avatar
[QUOTE=jefemente;2952613]Toyo M/T 285/75/17 on a RK 2.5 which netted me approx. 3.5-4" in the front.
Forgot to mention, 30 PSI is 33 inches tall. Procal vs GPS, MPH is dead on w/33".
Jeff
