Tires! Help!
Old Jun 28, 2013 | 02:25 PM
Smudgeontheglass's Avatar
Numbers on a metric sized tire: 285/70/17 - 285 is the tread width in mm. 70 is the sidewall profile, meaning the sidewall is 70% of 285, which is 199.5mm. Take the sidewall profile, convert to inches and multiply by two and add 17 (the wheel size in inches) and you'll get your wheel height. So this would be a 32.7" tire that is 11.2" wide on a 17" wheel.
Stock 17" wheels have I believe 3" backspacing and are 7.5" wide. Narrow wheels help keep the sidewall of the tire in the wheel (lower PSI while wheeling) but are generally harder to mount or reseat if you lose the bead and will look like a balloon. Most people will shoot for 4.25-4.5" backspacing and either an 8 or 9" wide wheel when running 12.5" wide tires. An 8" wheel would be perfect for a 285/70/17 tire.
(some of these numbers probably aren't correct but should be close)
Old Jun 28, 2013 | 02:34 PM
Tooadvanced's Avatar
To add to this. To convert to inches it is 25.4 mm per inch.
Old Jun 28, 2013 | 05:40 PM
swanny297's Avatar
Or go to online tire store and they have the overall diameter in inches listed in the specs of almost every tire
Old Jun 28, 2013 | 06:38 PM
SB2008's Avatar
well explained. I would also suggest a 285/70R17(33'') tire if you don't plan on a lift. the 285/75R17 is going to be taller(closer to 34''), but slightly narrower than the 285/70R17. the great thing about this forum is that there are endless pics and discussions on every aspect of the Jk including tires. just take some time and search through the forum and i'm sure the discussions and pictures will lead you to what you are looking for. Good luck!
Old Jun 29, 2013 | 06:50 AM
JK Inspired's Avatar
A 285 is 11.2 no if it is a 75/17 or 70/17. Visually, it might appear skinnier.
Old Jun 29, 2013 | 08:32 AM
RubiconGeoff's Avatar
Rubicon Moab wheels are 17x7.5 with 6.25" backspacing.
Old Jun 29, 2013 | 08:54 AM
knight1000's Avatar
One simple idea would just buy some rubi take offs (both wheel and tire). Then you just put them on and forget about it. Your JK would be fine with them.
Old Jul 9, 2013 | 11:31 AM
Doug Hicks's Avatar
Default Going By The Specs
Originally Posted by airborned
yes the 8" is just the with of the rim. some rims are wider like a 17 X 10" rim. but for the size of tires you want you a 8" rim will suffice perfectly. most tires mount on between a 7" and 10" rim easily. the wheels you want plus a 285 75 17 tire should mount and fill your tire well fine. the tire will come out to being about 33 x 11.50. x 17 in English.
Assuming the tire manufacturer is "true" to the tire measurements, in this case 285/75/17, you wind up with a tire that is 33.8 inches in diameter. If you are looking for a closer match to a 33-inch tire, you would go with a 285/70/17, whose diameter figures out to be 32.70. Long story short, there is more than an inch of diameter difference in those two tires.
