Toe in setting?
Just installed my TF 2.5 coil lift. Going to take it for an alignment. Curious to know if I should get them to set the toe in to a specific point? I have 33 inch tires and I am waiting on my jks track bar to center the axle. Will the uncentered axle affect anything? Thanks!
Originally Posted by Phrogmech46
I set mine 1/8th toe in, most shops align in degrees so its best to set toe yourself. With the lift you installed all you should have to do is center the steering wheel really.
1/8th inch works good.
If the shop has a real alignment machine they can easily set the machine to rear inches instead of degrees. Your toe won't change because of the lift but it is good to change the setting with the larger tires.
If you don't have the adjustable lower control arms your caster will not be able to be adjusted so it doesn't make any sense to get an alignment. All you need to do is adjust your drag link to center your steering wheel.
Pretty much yes.
I had a budget boost installed in my JK for a while running 33's and after I installed the budget boost all I did was adjust my drag link to center the steering wheel. I didn't even put it on the rack.
After I got tired of the budget boost I installed the Rock Krawler 2.5" X Factor Plus and needed to put the Jeep on the rack because everything became adjustable.
If you don't have anything adjustable it is not even worth checking the alignment. All you will do is look at it and say "I wish I had adjustable arms!"
Pretty much yes.
Toe in will help but it isn't 100% needed.
Castor will prevent death wobble as well.
