Torque
Old Aug 24, 2011 | 02:24 PM
EzK's Avatar
EzK
Someone should make a poll for who torque checks lug nuts. I'm certainly too lazy to do so but very curious.
Old Aug 24, 2011 | 02:28 PM
ronjenx's Avatar
From the factory service manual regarding lug nut torque:
[TABLE]
[h=4]SPECIFICATIONS[/h] [TR]
[TD="bgcolor: white, align: center"] [h=4]DESCRIPTION[/h] [/TD]
[TD="bgcolor: white, align: center"] [h=4]N·m[/h] [/TD]
[TD="bgcolor: white, align: center"]Ft. Lbs.
[/TD]
[TD="bgcolor: white, align: center"]In. Lbs.
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: center"]Lug Nut 1/2 X 20 with 60° Cone
[/TD]
[TD="bgcolor: white, align: center"]125-180
[/TD]
[TD="bgcolor: white, align: center"]92-132
[/TD]
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: center"]Spare Wheel Lug Nut
[/TD]
[TD="bgcolor: white, align: center"]54–108
[/TD]
[TD="bgcolor: white, align: center"]40–80
[/TD]
[/TD]
[/TR]
[/TABLE]
Old Aug 24, 2011 | 02:45 PM
CbtEngr's Avatar
Somthing I found out the other day when I was torquing my lugs to 95lbs. If you use an extension there is a formula you have to use to get the right torque. If you don't then you will actually be putting more than think.
Old Aug 24, 2011 | 02:59 PM
Mark Doiron's Avatar
Not exactly. If you use a crowsfoot to torque, place it at 90 degrees to the wrench or you will need to compensate. An extension w/n affect readings.
Old Aug 24, 2011 | 03:10 PM
rinkishJK's Avatar
95 n 100 are the same pretty much, unless ur talking about tty bolts on a head.
Old Aug 24, 2011 | 03:28 PM
ronjenx's Avatar
This type of extension will change the torque, unless it is at 90°.
This type of extension will not change the torque.
Old Aug 24, 2011 | 03:44 PM
Exactly.
