Towing
Old Jun 26, 2016 | 02:06 PM
denham45's Avatar
Default Towing
Anybody tow a pontoon boat with their Jeep unlimited ? We have a 20' pontoon and weights 2100 lbs completely full with everything in it. we are considering using the jeep to pull when we go camping with the fifth wheel.
Old Jun 26, 2016 | 02:24 PM
burton50x's Avatar
Should be no issue with your unlimited, you have a 3500# rating.
What trim JKU do you have?
denham45's Avatar
Rubicon with 4.10 gears.
Only concern is the wind drag having enough power to pull it
Old Jun 26, 2016 | 02:50 PM
burton50x's Avatar
Manual trans and the newer 3.6L would help if you have also, but if not you can still get the job done. Nothing is fun to pull behind the JK.
Old Jun 26, 2016 | 03:19 PM
denham45's Avatar
Have 2015 rubi with 3.6 , auto and 4.10's
Old Jun 28, 2016 | 10:05 AM
SOAZ JK's Avatar
I tow a 24' Bennington behind my '13. I have 5.13 gears.... slow and steady I won't tow over 65mph. As long as your trailer tongue weight is correct you'll be fine. Also, if you plan on using trailer brakes you'll need to wire up a 7 or 8-pin connecter.
Old Jun 28, 2016 | 12:15 PM
jedg's Avatar
Vet Army
The fellow with that can give you good advice on towing is rob_engineer... look him up on the member list.
Old Jun 28, 2016 | 04:38 PM
(none)'s Avatar
Speed won't be your issue, it's stability. Also the stock brakes are marginal. Pontoon boats aren't very aerodynamic, so you have to worry some about the wind moving it around a bit. Other than that, as long as you've towed in the past, you'll be fine. I've towed quite a bit more with my lifted 2dr on 35s. Far from unsafe, they just aren't great tow vehicles.
