tpms question?
Old May 8, 2011 | 04:18 PM
tracker's Avatar
Default tpms question?
Not sure how the tire pressure system works? When I put different rims and tires on I know I will have to reprogram them but will they connect to the new rim or how does it work. Or will it be disconnected all together? Thanks
Old May 8, 2011 | 05:02 PM
nthinuf's Avatar
If you go offroad, and choose to keep the sensors, consider having them banded inside. Those metal stems are easy to break, and they get expensive to keep replacing. (may have been replaced with rubber stems on newer JK's?)
If you choose to go without sensors, you will probably want a ProCal or Flashpaq to turn the system off.
Old May 8, 2011 | 05:06 PM
tracker's Avatar
Originally Posted by ECHO
They are held by a 12mm nut on the outside of the stem.. You can use them on your new wheels.. no reprogramming necessary
On the outside of the stem? Not sure I understand. Does it need to be disconnected before I take the stock tires off?
Old May 8, 2011 | 05:08 PM
tracker's Avatar
I'm getting a procal so I guess it will be off but I was just wondering if they had to be reconnected or what. IV never really looked to see how they work
Old May 9, 2011 | 12:40 PM
tracker's Avatar
Not sure which ones I have. Its a 2010 4 door sport with 17 in wheels
Old May 9, 2011 | 12:41 PM
tracker's Avatar
Pretty sure my valve stems are rubber
Old May 9, 2011 | 01:26 PM
BKGM Jeepers's Avatar
Mine came with the left photo-type stems above. They were aluminum. I still have them but took them off. I sure like the rubber idea for flexibility. I took mine off because I just could't risk tearing one off on the trail. I use a flashpaq to remove the warning and related system shut offs.
Old May 10, 2011 | 10:24 AM
greenenvey's Avatar
WhAt happens if you don't put them on your new tires and wheels? Will a alarm go on and stay on? Just courious because it might be a while before I can put mine on my new wheels when I get them.
Old May 10, 2011 | 10:29 AM
greenenvey's Avatar
Oh ok I was a little worried about a buzzer going off that would drive me insane lol
Nickit1981's Avatar
A light will stay on in your dash and it will ding once when your start your Jeep. It isn't that bad. I put them in my new wheeling tires just So I'd have something to remind me to air back up.
