TPMS question
Old Jul 8, 2008 | 12:34 PM
senor tortuga's Avatar
Default TPMS question
Maybe this is a question that has been asked before, but if you replace the factory wheels and tires do you need to change anything for the TPMS. I have heard two different things. Is there a sensor in the wheel or is it based on tire rotation.
Thanks for the help in advance
senor tortuga
Old Jul 8, 2008 | 12:37 PM
BaltChief's Avatar
The sensor is the tire valve stem.....unscrew it and use it in your new wheels.
Old Jul 8, 2008 | 01:24 PM
anyone know about how much to purchase new sensors. I am selling my OEM wheels.
Old Jul 8, 2008 | 03:36 PM
kcpanther's Avatar
take the sensors out of the oem wheels then sell them
Old Jul 8, 2008 | 04:57 PM
Littlejon's Avatar
You can get them through the dealership for around $50 a piece.
Mopar valve stem #56053036AAR
Vave stem retaining nut #56053037AA
Old Jul 8, 2008 | 05:09 PM
JulietKilo's Avatar
I had Discount tire (you can have any tire place do it) remove them from the stock wheels and install rubber valve stems into the stock wheels. They then inserted the TPMS into my new wheels for FREE! I figure they should after dropping 2200 bucks with them. You can see the gray valve stems in the new wheels. This is how you can tell if you have the TPMS or not.
Old Jul 8, 2008 | 05:18 PM
racer83l's Avatar
discount tire I believe sells them for $37 each...
I ordered a new set of wheels which should be arriving tomorrow and I ordered TPMS for them
Old Jul 8, 2008 | 07:18 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
you can get them at moparpartsamerica for $35 or live without them like I do lol, I dont even realize the ding at startup anymore lol.
moparpartsamerica.com/partlocator/index.cfm?action=getJointLocator&siteid=214583&Sec tionids=0,2413&groupid=20507&subgroupid=6282&compo nentid=&make=17&model=Wrangler&year=2008&graphicID =WJ07175&callout=1&catalogid=2&displayCatalogid=0
Old Jul 10, 2008 | 08:26 AM
snippy's Avatar
Can the TPMS valves be added *after* the tires are mounted/balanced on the wheels? It sounds like they can't.
I'm in the middle of ordering new wheels/tires, and they're wondering whether I want to pay $39*5 for new TPMS sensors.
Old Jul 10, 2008 | 09:01 AM
JulietKilo's Avatar
No the beads must be broken then the tires removed from the outside bead. Then the TPMS sensors are removed and/or replaced with rubber valve stems if you still want to sell or use the rims. They will then insert them into the new wheels and then add the tire.
