Trac bar bracket broke?
Old 06-19-2011, 02:14 PM
Lomax-dtl's Avatar
Default Trac bar bracket broke?
What should I do fix it myself or get the dealership to do it?
ID:	173313   Click image for larger version
ID:	173316   Click image for larger version
Old 06-19-2011, 03:05 PM
4play's Avatar
I'd have a welder repair & reinforce it.
Old 06-19-2011, 03:21 PM
Lomax-dtl's Avatar
How should i reinforce it
Old 06-19-2011, 03:57 PM
chknkatsu's Avatar
you can add some gussets to it
Old 06-19-2011, 04:18 PM
Robar's Avatar
JKS makes both front and rear track bar braces:
Front Trackbar Brace
Rear Trackbar Brace
Old 06-19-2011, 04:38 PM
riverrattcom's Avatar
Fix it with JKS Supports like posted above!
Old 06-19-2011, 07:41 PM
Lomax-dtl's Avatar
Will it work with the bds Tracbar relocation bracket?
Old 06-20-2011, 09:44 AM
aermotor's Avatar
Is that the rear trackbar?
I had my front break. Took it to EVO where they grinded the whole thing off and put on a new, much better track bar bracket from Dynatrac. That's what I'd do instead of trying to repair the existing one.
It looks like my rear is going as well so I'll mostly likely do the same thing, take off the old one entirely and get the EVO one.
Old 06-20-2011, 09:50 AM
Sponsoring Manufacturer
EVO MFG Representative
Andrew@EVOMFG's Avatar
Hard to tell from the pictures but it looks like the front is failing. Either way...
Front steering kit with much stronger upgraded trackbar bracket at the axle.
http://www.offroadevolution.com/stor...O-DRAGLINKFLIP
Rear upgraded trackbar bracket
http://www.offroadevolution.com/stor...d=EVO-REAR-RCC
Old 06-20-2011, 06:45 PM
Lomax-dtl's Avatar
Thanks but it's the front one but I got a friend of mine to weld it back on and he said that he could make a new bracket if it broke again. But here r some pics of it after he fixed it.
ID:	173794   Click image for larger version
ID:	173795   Click image for larger version
ID:	173796   Click image for larger version
Quick Reply: Trac bar bracket broke?
