Trac Bar question for the educated...
Old Nov 4, 2011 | 04:39 PM
michaelalabama's Avatar
Originally Posted by TheDirtman
Just erase the link. You will be fine.
Done. Sorry mods.
Old Nov 4, 2011 | 04:43 PM
fadeout's Avatar
you have a link to the Rusty's piece? just curious since I haven't seen it. and fyi the JKS is 1/4" steel too.
Old Nov 4, 2011 | 04:50 PM
fadeout's Avatar
http://rustysoffroad.com/mm5/merchan...ry_Code=BP-B_S
here you go. I can get a pict of mine installed if you like. I had the jks and it wore out in 8 months. It is not 1/4" unless they are making a new one.
Must be new, I only put it on 3 weeks ago. It's 1/4" They update their stuff way too frequently.
Shit man, were talking about 2 different things, I have their lower piece that's welded on and that's not 1/4" their upper brace is, sorry for the confusion.
Old Nov 4, 2011 | 04:52 PM
That's the one for the axle end right? If you went with this... what did you do for the chassis end and what kind of track bar did you use?
Old Nov 4, 2011 | 04:59 PM
Upper mount. I have the JKS track bar. They are coming out with a new one soon that will work with the steering box brace, the current track bar will not work with it . FYI
I'd like to see pics of your setup. Have any?
fadeout's Avatar
Funny I just got off the phone with their tech about using the Sector shaft steering kit with their track bar and he said it would work with my size lift but the newer version is for under 3 inch lifts since that;s where they were having the issues with it not fitting. Kinda why I ordered it up, guess I'll have to see when it gets here.
Old Nov 4, 2011 | 05:13 PM
jeeeep's Avatar
Originally Posted by michaelalabama
So in your opinion is the JKS a good tracbar? I've looked at the full traction as well. They both seem on par. Only thing is I can't find out what bolt size to use with the full traction TB. I guess they want you to reuse the old bolts... which I don't want to do. I really think that the threads on the factory bolts are part of the cause. They act like a dang rat-tail file in there.
The threads don't do much to increase the a hole that's already begin to get wallered out - this is caused by the TB bolt getting loose and the driving/wheeling forces jamming it around.
Get in the routine of checking all your bolts with each oil change or at least every other oil change. if you mark the bolt with a dab of paint, you can at a glance see if anything has worked loose.
Old Nov 4, 2011 | 05:38 PM
Dang man. You've done a lot of stuff to that jeep. Looks good.
Old Nov 4, 2011 | 06:14 PM
fadeout's Avatar
Hey Dirtman, did you actually try to for the steering brace up with the JKS trackbar? I'm trying to figure out why it doesn't work exactly and why they'd make a product that doesn't work with their original components. Jeeps looking sick, and I've been meaning to order up those spacers for my MTR's.
