Track bar
Have a shimmy in my steering wheel. I have checked everything but I think I have narrowed it down. When the jeep is sitting on all fours, should the track bar slide in easy. I did pry it in a little to get the holes to match and noticed the frame move when I pryed. Any help or thoughts. 3.25 rustys advance lift kit still on stock wheels
Have someone turn the wheels for you while all 4 are on the ground. That should help line it up.
I didn't do that, and ratched out the bolt on the drivers side. That ended up ruining the bolt.
When I first took the trackbar off for the lift install, it happend to be lined up ok, and the bolt came out. So I didn't know that before hand.
