Track bar bolts
Old May 5, 2011 | 06:39 AM
Danno2010's Avatar
Default Track bar bolts
When i replaced my stock track bar I also swapped out the bolts to 9/16 sholder bolts with nylon nuts with a washer on the head end to fill up the gap made at the factory in the mounts( not really a gap but replaced the orig bolts for a tighter fit) My question is this: I used grade 5 bolts because I didnt really have a huge understanding of the bolt grades until I did a little research..Will they be ok? Not going to do hardcore off road stuff just mild//Should I just upgrade to grade 8? Thanks..
Old May 5, 2011 | 07:04 AM
Jetspd67's Avatar
I would use G8 hardware. Also, I would replace the nyloc nut with an all metal top lock. If you have a Fastenal near by, they will be able to help. Upgrading to G8 is cheap insurance.
Old May 5, 2011 | 07:08 AM
wayoflife's Avatar
JK-Forum Founder
factory uses a metric 10.9 and i would use no less than a grade 8.
Old May 5, 2011 | 07:24 AM
Dex1's Avatar
Any time I switch out a bolt, I use grade 8, no sense taking any chances...
Old May 5, 2011 | 11:43 AM
Danno2010's Avatar
Thanks for the info guys... I will change em up....
Old May 5, 2011 | 12:09 PM
jeepin_tiger's Avatar
Call fastenal, or visit their website, and order the grade 8 bolts and jam nut. Since it is an unusual size they will likely have to order, and you will probably have to buy a pack of 10. Still should be less than $20.
Old May 5, 2011 | 12:57 PM
AussieTom's Avatar
Default Bolts
Metric grade 10.9 is almost equivalent to UNF Grade 8. U must use UNF though. A Grade 5 UNF 9/16 can only torqued to about 110 pds from memory. i have the charts somewhere. Also, use High tensile washers, not standard ones as they can squash a little.
I replaced my lower control arm bolts as well, and have the uppers ready.
Old May 5, 2011 | 01:15 PM
pcmasten's Avatar
Veteran: Marine Corp
I had a nylock nut come off my tie rod. I'd go with the metal top lock nut.
