Track bar with bracket?
I happen to like animals, so I wouldn't kick a dog. I don't have a problem with anything at all. All I was doing was saying to do a search and you will see that the relocation brackets cause problems. It has been discussed in depth.
Not all track bar brackets are the same!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
A propperly designed trac bar bracket will give you better handling and better steering geometry (less bump steer).
Just because one track bracket fails does not mean that all track bar brackets are junk.
Yes, I've seen all the failures due to the bracket, If you do a search you'll find that most of the failures come from the same brand/brands, and in some or most cases they have come up with a "fix" for the problem.
Track Bar Bracket is designed to correct steering geometry.
Adjustable Track Bar is designed to re-center the axle (front or rear) after lifting.
