track bar drop bracket
Old Aug 23, 2008 | 01:55 PM
WIRINFRENZY's Avatar
Default track bar drop bracket
i installed my new tera 2.5 bb w/ longer shocks last night. everything went pretty smooth except the bracket. it would not go far enough inside the original for the hole w/ the spacer to line up. i had to break out the grinder and take some off the bottom of the factory mount. once i took off about an 1/8" it went in enough. just wondering if anyone else ever ran in to this?
i do say though that the lift is awesome. my jeep looks so much more solid now. rides pretty much the same. i really didnt notice any off center w/ my steering wheel either. do you always have to re-center it? i swear i cant tell if it's off
Old Aug 23, 2008 | 02:36 PM
RubiRascal's Avatar
Yup Had to do the same thing when Sasquatch and I installed my the
2.5" coil lift. We ended up grinding a slight bevel on the inside of the factory mount until it fit! Don't forget to rattle can the bare metal when you're done. I also didn't have to touch my steering alignment.
Old Aug 23, 2008 | 02:53 PM
Greenmachine's Avatar
Yeap same here I had to grind a little to get it to fit tight on the bracket. I had to realing my steering, but only ever so slightly.
Old Aug 23, 2008 | 03:17 PM
thanks, i dont feel so bad for chopping at my ride now!
