Trackbar 14mm bolt 16mm hole issue
I thought about taking the same approach with the bushing a while back. If its only 1mm thick its not going to be cheap to get the strength you probably need. But (and I havent looked to see if this is a better option) you could always drill the hole a bit larger and then put the bushing in. That way you get the right sized hole and a thicker bushing. If it works well you could probably find someone to make some out of stainless and even heat treat them for under $10/ea if you have the demand for them.
