Trackbar Issue
I have a JKS front adjustable trackbar that has a jamnut that continues to come loose no matter how tight I make it. Anyone know why this is happening or does is this happening to anyone else? The same thing happens on my Rough Country front lower control arm jamnuts. What are the negative effects of thes loose jamnuts on the threads of the trackbar and control arms? Again everything was tightened pretty significantly when installed. Thanks
It doesn't realy matter if it cones lose cause the while controll arm or track bar has to spin to make an adjustment. Clean the threads with some soap and a toothbrush to get all the grease off than put some blue loc tight and tighten it back down. Blue so if you need to make an adjustment it will be easier to get off .
I've used a stuff called Automotive Goop (think thats the name, not at my house right now) Never had a jamnut loosen with it, plus, you can peel it off if future adjustments need to be made.
Edit. Amazing automotive goop is the name.,
I used this stuff to keep my front fender flares from flapping after they were trimmed. I've hit the passenger side heard enough to bend the support braket but the Goop held!! Very tough stuff.
Thanks guys the loctite was going to be my next step. I guess my question is can I do any damage to the trackbar itself seeing that I am putting a lot of pressure on the threads. Im assuming the jamnut is suppose to absorb most of that force. If my jamnut keeps coming loose can it be related to other issues?
