Trackbar Issue
Originally Posted by brobbins67
I use RED loctite. Do you want it to stay put or be easy to loosen?
It doesn't realy matter if it cones lose cause the while controll arm or track bar has to spin to make an adjustment. Clean the threads with some soap and a toothbrush to get all the grease off than put some blue loc tight and tighten it back down. Blue so if you need to make an adjustment it will be easier to get off .
A friend of mine just completed a fresh build on his TJ... once all the angles were finalized on the front 3-link and rear 4-link, he gave all the jam nuts one last torque, followed by a couple small MIG tacks (between the Jam nut and sleeve - not on the threads directly). That'll lock it down good
Check with Dave at Northridge to see if these would work...
http://www.northridge4x4.com/proddet...od=EVO-LINXLOK
If the threads do wear after an extended period of time with the jamnut loose and the trackbar gets damaged could this move the steering wheel offcenter or is it just the draglink and tierod that does that?
I have a JKS front adjustable trackbar that has a jamnut that continues to come loose no matter how tight I make it. Anyone know why this is happening or does is this happening to anyone else? The same thing happens on my Rough Country front lower control arm jamnuts. What are the negative effects of thes loose jamnuts on the threads of the trackbar and control arms? Again everything was tightened pretty significantly when installed. Thanks
