Trackbar - Tera or FT
Comparing baja to a jeep off road is like apple and oranges. Most baja racers do not run a track bar. They run a triangulated set up. Their articualtion is problably better than 99% of jeeps. They run over 24" of wheel travel. Jeep track bar bracket have been weak ever since the TJ. The added stress of the relocation bracket on the axle is making it worse. Skyjacker has fixed their problem with a bracket that goes from the pumpkin to the track bar. This stops the stress of the pulling track bar. This is something that even stock track bars should have. I had one on my tj before I went to a triangulated set up.
(unless someone can talk me out of it) :<)
AHH, I mean show me a better setup..!!!
I agree that the relocation brackets are not a good idea but most of them seem to be working fine. I wheel my jeep pretty hard and iv had no trouble with my FT rear bracket which is one that comes down from the body. The best solution is using a longer track bar. It really wouldn't be that hard to re-inforce the stock brackets or build new ones out of a thicker plate.
I just wanted to point out that I don't think the triangle setups provide any better articulation than the track bar systems. Iv always thought the big benifit to the triangle systems is that you can set the rear axle further back, the rancho system used the triangle behind the axle so im still not sure what the benifit of this is. It may prove to be a stronger setup but it will also prove to be expensive. Im happy with my rear track bar and the only thing I will probably do in the future is replace it with an adjustable one. Just my 2 cents.
Having had a jeep with a triangulated set up, I will say that the flex is greatly increased vs. a trackbar set up. However, the racho setup on a jk might not be that way because it is from the rear. i personally have never seen this type of setup.
how exactly does a triangulated system greatly increase flex? Im not trying to say your wrong but please help me understand. The limiting factors in my mind are the shock and sway bar first, then control arms. The trackbar never limits the flex.
I too run a tri-link in the rear of my TJ and have seen much better articulation on the trail. But then, that's just me
In a couple weeks, i'll be getting my lift kit, along with the adjustable trackbars for front and rear
The question is, which one is better: Teraflex or FT. WOL did a write up on FT, and it seems like it's a good trackbar. Anybody knows the comparison between the two?
Thanks for the insight
Now, I can't speak for anyone else who has been having problems with their track bar as I did not do the installtion but for me personally, the Full Traction track bar has been great. And, I should point out that this opinion comes from at least 3,000 miles of hard use and abuse on and off the trails.
