Traction control on my j.k.
Old Feb 28, 2011 | 01:33 PM
DEVINL's Avatar
Default Traction control on my j.k.
I had a four inch superlift suspension lift installed on my 2008 j.k. Unlimited. I changed my tires to 285/70/r17 and now everytime i make a sustained turn my traction control activates. Is anyone having the same issues and if so, can anyone tell me how to fix it?
Old Feb 28, 2011 | 01:41 PM
river2c's Avatar
It sounds like you need to recenter your steering wheel. Follow the directions in this link:
http://project-jk.com/jeep-jk-write-...-end-alignment
Also, did your lift kit come with an adjustable track bar? Make sure your axles are centered before you center the steering wheel.
Old Feb 28, 2011 | 01:49 PM
backwoodjk's Avatar
Increasing your caster with front adj. control arms helped me a ton with this issue. I can haul ass around corners with no jeep nannies slowing me down.
Old Feb 28, 2011 | 02:26 PM
Dan415's Avatar
Default Castor
Yep, check your wheel... if its good then its probably caster... if your lift didn't come with adj. lower control arms then lowering your tire pressure might help a little.
Old Feb 28, 2011 | 09:18 PM
DEVINL's Avatar
Originally Posted by river2c
it sounds like you need to recenter your steering wheel. Follow the directions in this link:
also, did your lift kit come with an adjustable track bar? Make sure your axles are centered before you center the steering wheel.
thanks for the help. It's pulling to the right, should i adjust the steering to the left?
Old Mar 1, 2011 | 04:32 AM
Rhino64's Avatar
If its pulling to the right that sounds like a different issue. It could be something as simple as low tire pressure on that side. I can't say what the cause is but I'm sure somebody will chime in with some help.
