trailer hitch
Old Dec 17, 2011 | 11:20 AM
JK x 2's Avatar
Default trailer hitch
what is the best bolt on one out there to buy if you dont already have the mopar installed tow package HELP
Old Dec 17, 2011 | 11:36 AM
IndyChavez's Avatar
You can find the four bolt one on eBay for 60 bucks or something like that
Old Dec 17, 2011 | 01:49 PM
notsoricer's Avatar
i have the rugged ridge hitch. although their harness is really good, the hitch has some major QC issues. the outer sleeve is welded like crap and makes it look crooked. the weld has sharp, jagged spikes where you can really do damage to your hands, and not to mention, the nuts arent welded on like the picture advertises. so you have to either remove the bumper or finagle the washers and nuts in a half inch of clearance. i'm going for mopar
Old Dec 17, 2011 | 02:21 PM
lari88's Avatar
I have a Reese 1.25" I would sell ya for like 30 or 40 bucks
Old Dec 17, 2011 | 02:28 PM
Twinkydog's Avatar
I have the same hitch and didn't notice any weld issues. The nuts are not that bad if you tape the washers to the hitch before putting it under the jeep. I installed mine in less than 30min without removing the bumper.
Old Dec 17, 2011 | 05:23 PM
WXman's Avatar
I bought the Hidden Hitch brand specifically because in all the pics I saw online, the chinese Rugged Ridge/Smittybilt hitch looked like it was welded by a high school shop class. Also, the SB/RR hitch is designed so that the safety chain attach points are directly underneith the pin hole and that can be a pain. Finally, the RR/SB hitch doesn't stick out quite as far. This can lead to issues with the spare tire, depending on how your trailer's dolly is set up.
So I got the Hidden Hitch and Hidden Hitch wiring harness ($90 total) and couldn't be happier so far. Installation took 10 minutes. The hardest part was dropping the muffler for easier access to torque the bolts.
Old Dec 17, 2011 | 06:30 PM
RSTRICK's Avatar
I would go with the Mopar hitch and harness. Installs very easy no need to drop your muffler or tape nuts and washers on it . Install took about 30 min on mine.
Old Dec 17, 2011 | 06:34 PM
09jaykay's Avatar
X2 on the mopar hitch!
Old Dec 18, 2011 | 06:50 AM
ranjr's Avatar
I got the Smittybilt hitch and Rigged Ridge wiring harness from Amazon for $72 shipped to my door. I read about the issues with the welds but mine looks great. I loosened four bolts for the rear plastic bumper to allow room to install. No issue.
Old Dec 18, 2011 | 04:16 PM
IR Tools's Avatar
I had good luck with the Rugged Ridge hitch and harness. When installing I found that it's much easier if you use some double stick tape to hold the washers in place on the nut side.
