Transfercase output shaft slop!
Does anyone else have just the slightest bit of movement in their front output shaft on the transfercase?
I stopped at the local dealership and crawled under two new ones and could feel the slop in these new ones also.
If you can let me know by grabbing the front flange and giving it an up/down and side/side to see if there is any slop or if it is rock solid like the back output shaft.
I noticed this also, after changing to Coast DS front and rear. I have been thinking about this and believe it might be because the front out put shaft is not engaged. I have not had time to check and see if goes away, once you engage 4wheel drive.
Yeah, if you felt this when inspecting a unit bearing you'd replace it. It feels like worn bearings, but apparently they are made like this.
Sent using my SuperSmartThinky Phone
I know it's weird, when I could feel it in a brand new one I thought it was normal. I am just trying to get a feel for how many others have the same issue. Maybe if everyone reports the same thing we could all call it normal. Maybe if only 50 percent have it then it would be something to be concerned about.
How long have you been running your coast shafts?
I know what you're saying, I feel the same way about this. My friend's Jeep has this as well but a little worse. He has a '10 Sahara and I have an '08 Rubi. When I pulled the flange off to install the yoke for my 1310 ds a lot of fluid came out so I can't imagine it not being well lubricated.
I put on a coast front driveshaft a week and a half ago and rolled my front pinion to 2.5 degrees up which gives me a 3.5 degree caster. I have no vibes, steers great, no issues at all. I am running a 4.5" BDS lift.
