trek top question
Old Sep 29, 2009 | 05:35 PM
vincentinvasion's Avatar
Default trek top question
can factory door surrounds be used with trek top? If so are the results better?
Old Sep 29, 2009 | 07:27 PM
pastorsteve's Avatar
Don't know but your new top should come with door surrounds. Probably won't as the Trektop is designed differently than a factory soft top.
Old Sep 29, 2009 | 07:32 PM
Piginajeep's Avatar
No they cannot,
the trektop uses its own hardware.
Old Sep 30, 2009 | 06:03 PM
customer service at quadratec said they can be used. Would that be correct? I have the trek top now and was going to pick up a set of the factory surrounds thinking they may work better and be of higher quality and help stop water from running in around the surrounds that the top came with. I have the new version of the trek top just for the record.
thanks for replies
Old Sep 30, 2009 | 06:16 PM
Piginajeep's Avatar
thanks for replies
theres no way, the trektop wraps around the new door surrounds, the stock ones will not work.
Old Sep 30, 2009 | 06:17 PM
dpoelstra's Avatar
I found that the Trektop door surrounds are quite water tight with the full doors. I tried to get water in with a spray nozzle and could not get a drop inside. Some have leak issues, but you can also bend the mounting tabs a smidge to kinda custom fit the surrounds to the door.
I also found that I lost some annoying rattles once the stock surrounds were off.
I would be surprised if the stock ones work. but no harm in trying. Just don't discount the quality of the aftermarket. I find the entire set up quieter than the stock soft top...regardless of other's horror stories.
